What oil is best????????????????
Old 10-03-2005 | 08:47 PM
marc4x4's Avatar
marc4x4
Default What oil is best????????????????
Hi i have a 91 saph 4x4 stage 3 and as i have only just got it i am giving it a full service i was wandering what your recomendations for oil and spark plugs are? i will use a ford oil filter? also any thing else that needs doing regularly? cheers
Old 10-03-2005 | 10:25 PM
martinmace's Avatar
martinmace
the most expensive you can find and as for doing regular the expensive oil you put in your motor ,you should check daily cos they do use it some more than others 5/40 fully synthetic
Old 10-03-2005 | 10:28 PM
marc4x4's Avatar
marc4x4
Thanks going shopping tomorrow!
Old 11-03-2005 | 06:29 AM
wimwerf's Avatar
wimwerf
im using 10w60 from valvoline.....good oil for me....
remember a stage 3 engine gets a lot warmer then a standard engine on some places......
Old 11-03-2005 | 04:10 PM
oilman's Avatar
oilman
If you want the best quality and price is not an issue then I would use the Silkolene PRO S 5w-40 or 10w-50. It's 100% synthetic, no petroleum basestock.
Top oil and top protection
http://www.opieoils.co.uk/TechSpecs/...04%20Wheel.pdf
Its also discounted here:
https://passionford.com/forum/viewto...561&highlight=
Simon
Brickhouse
14
03-10-2015 08:28 PM
DAZZER
30-09-2015 09:43 PM
Fudgey
21
30-09-2015 07:19 PM
deathrider666
28-09-2015 07:12 PM
Quick Reply: What oil is best????????????????
