Problem with wipers, Focus ST170
Old Jan 9, 2013 | 10:52 AM
robotechnics's Avatar
robotechnics
Default Problem with wipers, Focus ST170
Does anyone else have this problem or know how to fix it?
When I press the wiper stalk down to operate the wipers for 1 wipe if i let go of the stalk the wipers stop. I would of thought that these would automatically finish off the action.
Also i've noticed that if you put the wipers on the first setting if you return the stalk back to off the wipers stop in the middle of the screen. Are these problems related?
Is this a dodgy wiper relay or something more sinister?
All help and advised is greatly appreciated!
Thanks
Old Jan 9, 2013 | 11:18 AM
doga-ot's Avatar
doga-ot
It is related, it used too do this on my saph cossie but it sorted itself out, maybe faulty relay or motor
Old Jan 9, 2013 | 11:26 AM
robotechnics
All the other settings seem to work ok. Do you know where i can locate this?
Old Jan 9, 2013 | 11:30 AM
doga-ot's Avatar
doga-ot
I could be wrong but i think relay is on/in stalk if not it will be behind glove box!
Old Jan 9, 2013 | 04:49 PM
mattxr3i's Avatar
mattxr3i
Relay in the fusebox behind the glovebox. Replacement solved the problem on our old Focus and it is so common that Ford keep the relay on the shelf
Old Jan 10, 2013 | 11:39 AM
robotechnics
I don't suppose you know what colour it is?
Thanks
Old Jan 10, 2013 | 12:35 PM
doga-ot's Avatar
doga-ot
There should be a diagram on back of glovebox
Old Jan 10, 2013 | 06:39 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Does this apply to older cars too?
My series 2 refuses to park sometimes. Intermittent function is intermittently faulty.
I assumed it was the motor worn inside.
Old Jan 11, 2013 | 08:24 AM
robotechnics
Spoke to Ford and they wanted £26.99 for the relay and Brand new ones on eBay are still over £20.
Does anyone have a spare one for sale? Does anyone know if there is somewhere on the forum that sell spares?
Done some digging and this is the one i need:
Part number on relay – 6X4T 14B192 AA
Ford Finis Number- 1552133
Old Jan 11, 2013 | 08:46 AM
The Underdog's Avatar
The Underdog
you cant fix stupid
i have 2 170s and they both have this problem. i just live with it
Old Jan 11, 2013 | 08:53 AM
minder's Avatar
minder
£5.00 each in the breakers yard mate or just go to any local motor factors and they
sell them off the shelf job done
Old Jan 16, 2013 | 06:36 PM
robotechnics
Update: Bought a relay from ebay swapped it over ans still the same problem. The relay i changed is pictured below as R19.
Anyone else know if there is another relay that might need changing or could it be the wiper stalk? Thanks
Old Jan 16, 2013 | 06:39 PM
doga-ot's Avatar
doga-ot
maybe a faulty motor then bud, but as i've seen on here seems to be a common fault on st170's
Old Jan 16, 2013 | 06:55 PM
RichieST's Avatar
RichieST
My money would be on the motor mechanism. It should have a little switch inside it that tells it that it's at its stop position.
Old Jan 20, 2013 | 11:49 AM
robotechnics
Finally got this sorted! The breakers sent over 2 relays which must of been the rear and front from another Focus. I swapped both of these over with out thinking and still had the same problem.
I then changed the front one with the original rear wiper relay and all good!!
Thank you everyone for your help and advice!
Old Feb 20, 2018 | 11:52 AM
Prefect57's Avatar
Prefect57
I can't get the intermediate to work for front and rear wipers new rear motor and wiper switch relays etc and still no intermediate help appreciated
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Aug 28, 2015 01:32 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
