knocing engine
Old Apr 27, 2004 | 03:54 PM
rossatom2's Avatar
rossatom2
Default knocing engine
just started my cossie engine the othewr day that i have rebuilt and it is knocking it sounds just like a diesel, before i rebuilt this engine it was making this noise after just swapping the head but now i have replaced the crank,all bearings,bolts,rings,gakets, infact the only parts still from the old engine are the BLOCK,RODS AND PISTONS they are all in good nick.so the only reason i can see for the noise is that the TIMING.
i set the boittom pulley to the lug before the groove, the top pulleys to each other and the aux pulley to the middle of the half moon.
i'm sure this is right but i can't think what else it caqn be this engine has been killing me 4 nearly 2 years and there is not much else i can replace.
after it had made this noise before i noticed slight marks on the pistons from the valves ,but like i say the timing looks bob on..
maybe someone can shed some light on it.. cheers
Old Apr 27, 2004 | 04:30 PM
Alvyn's Avatar
Alvyn
Default Re: knocing engine
the head you fitted DID IT HAVE ENOUGH MEAT LEFT ON IT FOR THE VALVES TO CLEAR THE PISTONS?
Old Apr 27, 2004 | 05:23 PM
Nik_W's Avatar
Nik_W
Piston slap has a slight diesel sound to it when cold but should quieten down once warmed up. Would be a shame if it is piston slap seeing as you replaced everything else on the bottom end.
Old Apr 27, 2004 | 05:33 PM
rossatom2's Avatar
rossatom2
the head has not been skimmed and has been checked by the local engineering firm....
it is much loader than piston slap, it sounds just like the pistind tapping the valves .
Old Apr 27, 2004 | 05:37 PM
Tony Ryan's Avatar
Tony Ryan
Move the crank position to the "Groove " itself , not the lug before !
Old Apr 27, 2004 | 05:54 PM
alan rainbow's Avatar
alan rainbow
do not move crank to groove or the valves will hit the pistons
Old Apr 27, 2004 | 05:55 PM
alan rainbow
did you change little ends
Old Apr 27, 2004 | 06:10 PM
Alvyn's Avatar
Alvyn
DONT THINK YOU SHOULD DO THAT M8!!
what cams are fitted to the head standard or ???(if not think up to BD10's are ok!)after that your pistons will need cut outs!
Old Apr 27, 2004 | 07:03 PM
rossatom2's Avatar
rossatom2
the cams are standard yes, and noppe i did not chane the little ends
Old Apr 27, 2004 | 07:09 PM
Tony Ryan's Avatar
Tony Ryan
My error , was waiting for someone to correct me !
Have seen this before when the crank has been set in the incorrect position but couldn't remember which way it was !
Old Apr 27, 2004 | 07:11 PM
alan rainbow
sounds like little end or piston slap mines got a knocking when cold but clears hen warm was advised it to be little end wear or piston slap did you have bors checked for wear when engine was out
Old Apr 28, 2004 | 08:14 AM
rossatom2's Avatar
rossatom2
this has entered my mind but the noise is just like an old bus really load i would of thopught far to load to be that..
the first time this started i had just changed the head gasket wen i started it it was perfectly quite, i drove down the ro0ad as i was driving it was getting loader and loader, by the time i got about 10 miles it was so load and shaking i had to tow it home, thats wen i stripped it, first thinking it was top end, then sow that the bearibgs were ready, i don't know what else can where that fast, cheers
Old Apr 29, 2004 | 03:34 PM
rossatom2's Avatar
rossatom2
is there any way the cam belt could be streching inder load, if this was the case would the marks still line up after the engine was turned off???
i'm trying every possability
Old May 1, 2004 | 04:54 PM
alan rainbow
ERRM NO looks like you gunner after strip it again
Old May 2, 2004 | 09:43 PM
Default noise
HI.
When you changed the head did you change it complete with
cam followers, cam and valves, or stripped yours if you used your parts
did you keep the cam followers in order to the cam lobes for your cams
or put in any new followers, if so did you run the cam in to them.
and the valve timing the lug you used is the edge of the lug to the
pointer left part of lug. ps before u strip it again? do a compression test.
and what is your oil pressure like as you have new bearings,should be good if pump is ok.
maybe the bearings are the wrong size.for the crank mains or bigends.
Dave.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
