Mk1 focus central locking problem???
Old Jan 6, 2013 | 11:12 PM
TobyBrindley#12's Avatar
TobyBrindley#12
Default Mk1 focus central locking problem???
Hi guys, just got a 5dr mk1 focus and the central locking doesn't work. I changed the battery in the key and its still the same. When I press the buttons nothing happens, but if I put they key in the door an turn it, it electronically locks/unlocks all the doors fine. Anyone got any suggestions? Maybe a fuse somewhere? Or a wire burnt out?
Thanks on advance
Old Jan 6, 2013 | 11:23 PM
stboy's Avatar
stboy
Sounds like you need to try and recode the remote. Turn ignition on to position 2 and off about 4times or until a beep is heard. When you hear the beep Press any button on the remote then turn ignition off. Back on and off again and try it. If that doesn't work try getting the remote tested but it could be it requires a new remote fob. Hope this helps
Old Jan 7, 2013 | 12:15 PM
martysmartie's Avatar
martysmartie
Old Jan 7, 2013 | 10:38 PM
TobyBrindley#12
ok thanks guys and no its the 1.8 zetec LX air con model
why would the model make a difference?
Old Jan 8, 2013 | 11:37 AM
martysmartie
Your is an LX, Zetec is a different model
CL does not have remote central locking, hence I wondered if someone tried to add it.
If you look in the handbook there is instructions to pair the key (assuming it works), it's something like turn the ignition on/off several times quickly to put the ECU into "learning mode".
Martin
Old Jan 8, 2013 | 12:14 PM
minder's Avatar
minder
check the fuses mate they are behind the glove box its easy to get at open the glove box
and at the side there are two lugs push them in and the box will drop down undo the fuse box (2X10mm nuts the fuse your after is number 63 its 20 amp and yellow (its on the rear of the fuse box mate)
Old Jan 8, 2013 | 05:30 PM
TobyBrindley#12
Martin
Hi, I know it is an LX i meant it was zetec engined and ok. i tried reprogramming the key and it didnt work
Old Jan 8, 2013 | 08:29 PM
martysmartie
The fact the CL works means this is fine.
OP, you might want to verify the remote is transmitting, if your good with electronics you can verify the operation of the switches etc, but to see if it's actually sending a signal is a little harder.
Martin
Old Jan 8, 2013 | 09:11 PM
TobyBrindley#12
Martin
how do i do this?
Old Jan 8, 2013 | 09:21 PM
martysmartie
Just verify power is present at various points on the PCB, tbh you really need to be conversant with circuit boards etc so you know where to look, it just can disperse the theory of a bad battery connection etc, and that the switches have continuity.
I would say the remote is more likely at fault than anything else.
Martin
Old Jan 8, 2013 | 09:24 PM
TobyBrindley#12
Martin
ok thanks how much is a replacement normally?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
tankybaby66
Aug 9, 2015 07:13 AM
