Orion Mk1 Zetec conversion oil pump
Old Dec 20, 2012 | 08:28 PM
ZeroLWD's Avatar
ZeroLWD
Default Orion Mk1 Zetec conversion oil pump
the guy who does the zetec conversion in my mk1 orion has a small problem with the oil pump. He said he had to order a mondeo pump but now it turns out some part numbers don't match. Is this a problem or will it just bolt straight on?
the zetec is a 1.8 from a mk6 escort (last model).
he did the conversion twice with mondeo engines and no problem with the pump.
Old Dec 20, 2012 | 09:45 PM
slammedorion's Avatar
slammedorion
You want a fiesta, escort or orion 1800 sump.
Along with matching oil pump.
Mondeo sumps are flat, where as the above have a section out of the centre for the exhaust to go through.
Old Dec 20, 2012 | 09:56 PM
ZeroLWD's Avatar
ZeroLWD
well it's an Escort 1800 engine, so the original oil pump should fit? I was told it doesn't fit and that it has to be replaced with a mondeo pump
Old Dec 20, 2012 | 10:12 PM
zippyobrien's Avatar
zippyobrien
Ideally you change to a fiesta oil pump as its shallower. Orrrr
Leave it alone and fit a Renault 5 oil filter as it shorter. As yo have a escort sump you don't change that either
Old Dec 20, 2012 | 10:21 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
people usually replace the mondeo pump with the escort/fiesta one as the escort/fiesta one is angled at the back so the filter sits in a better position whereas the mondeo one sticks straight out.
Old Dec 22, 2012 | 02:40 PM
ZeroLWD's Avatar
ZeroLWD
he said that for a Mk4 Escort a Mk6 Escort pump will work but not for a Mk3. It really does not fit on the engine mount...
the donor car is a mk6 Escort:
big_Rad
Sep 15, 2017 09:36 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Dubs44
Aug 21, 2015 02:42 PM
track.focus'd
Aug 12, 2015 05:53 PM
