starter motors
Old Dec 10, 2012 | 05:51 PM
little6872's Avatar
little6872
Default starter motors
hi folks i am new to this forum got a problem which i think someone on here will know the answer im building a kit car with a ford ohv mk2 escort engine and box and have hit a problem. the pre engaged starter that come with it wont fit as the chassie fowls the solenoid on the starter so cant get it in .a way round it is to either cut and weld the chassie so it can go in or i thought a mk1 escort starter without the solenoid which would fit in no problem. but i need your help on that one will a mk1 starter bolt straight on and work or is the bolt holes different or the teeth .the pre engaged one has 3 bolts and i know the mk1 starter only has 2 any help would be very much appreciated thanks regards paul
Old Dec 10, 2012 | 06:43 PM
cabriolet's Avatar
cabriolet
not sure what u mean fella but the inertia starter ie without solenoid for a mk1 escort is 10 tooth 3 plain bolt holes, so is the pre- engaged ,the problem u have is the leading edge of the ring gear is on the front for pre-engaged on the back for inertia ie where the pinion engages it will work but the pinions wont last
Old Dec 10, 2012 | 07:20 PM
little6872's Avatar
little6872
hi thanks for the reply when you say it wont last do you mean weeks/months just this will only be used for a few months a year in the summer thanks
Old Dec 11, 2012 | 04:22 PM
cabriolet's Avatar
cabriolet
when we did it on road cars they lasted about 6 months fella probably last forever on a summer car
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
