"Deep" mondeo ecu remap
Old Dec 5, 2012 | 08:12 PM
skippy312's Avatar
skippy312
Default "Deep" mondeo ecu remap
this may sound like a daft question !
but is it possible to remap a std non pats zetec ecu ?
if so how ?
thank you all
Old Dec 7, 2012 | 08:47 AM
sailorbob's Avatar
sailorbob
It depends on what you mean by 'remap'. If you mean reprogramming the original eprom then it can be done but I'm only aware of two people who have ever done this. If you mean change the calibration data then yes it can be done and the revised calibration is usually programmed into a J3 chip adapter.
Old Dec 7, 2012 | 09:32 AM
skippy312's Avatar
skippy312
Default timing
thanks for your reply sailor bob !
all iwant to be able to do is change the timing as i want to run more advance.
i should probably point out that the ecu on this vehicle is only used for the coil pack as i have carbs fitted .
i really would like to be able to do this my self but dont know where to start.
many thanks skippy312
Old Dec 8, 2012 | 03:17 PM
sailorbob's Avatar
sailorbob
I'm not aware of any publicly available definitions for the GSBB0 strategy (which is what the DEEP ecu uses).
Old Dec 8, 2012 | 03:28 PM
black_jack's Avatar
black_jack
Black Jack
it may be possible to simply move the position of the crank sensor (mechanically)
Old Dec 17, 2012 | 05:30 PM
Rob_DOHC's Avatar
Rob_DOHC
It would be easier to install a megajolt to control the ignition tbh.
Rob,
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
griffo69
Oct 4, 2015 11:58 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
