Cosworth YB cam pulley timing position
Old 03-12-2012, 09:35 PM
andyb64
andyb64's Avatar
Default Cosworth YB cam pulley timing position
Hi, I'm in the process of changing the cambelt on a 2wd YB engine. I set all the timing marks as per various threads on here ( couldn't set the dizzy as engine came without one ). However when I released the tensioner pulley and removed the belt both the cam pulleys shifted out of alignment. They are both now about 1 tooth above the level of the head. Is this normal as when I turn the pulley to the correct position it seems to be opening valves on number 3 cylinder. Do I just turn them into the correct position and hold them there while I fit the new belt ?
Thanks in advance for any assistance
Andy...
Old 03-12-2012, 10:36 PM
botters
competant bodger
botters's Avatar
yes just turn them till they are pointing at each other, they dont always point 100% at each other due to machining tolerances but so long as they are close enough for the belt to locate across the teeth properly it will be fine, just make sure you turn the engine over twice by the crankshaft pulley after fitting to make sure nothing is making contact and you will be fine to start it
Old 03-12-2012, 11:13 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
and then re-check ALL the timing marks are still aligned, this is crucial.
making sure all the bolts are torqued properly
000 (26-12-2018)
Old 04-12-2012, 01:24 PM
andyb64
andyb64's Avatar
So the fact that the pulley won't stay in the correct position unless I hold it in place with a spanner while I fit the belt doesn't matter ?
Old 04-12-2012, 04:23 PM
manoj
manoj's Avatar
This should help mate.
Make sure Piston No.1 is at its highest point @ TDC first, then follow the diagram.
thanks,
Manoj
Old 04-12-2012, 04:49 PM
andyb64
andyb64's Avatar
The problem is I can't get the pulleys to stay in those positions without holding them there with a spanner while I fit the belt. Is it normal for this to be the case or are my cams in the wrong position in relation to TDC ?
Old 04-12-2012, 08:25 PM
grcossie
grcossie's Avatar
Thats no problem, use a spanner and fit the belt. Turn crank twice and check timing.
Old 06-12-2012, 10:01 PM
andyb64
andyb64's Avatar
Thanks everyone for all the advice, took a couple of attempts to get it right but new belt fitted and everything lines up nicely, thanks again
Andy...
Old 23-07-2014, 11:12 AM
gi2490
gi2490's Avatar
nice. needed this
Bailes1992
16-08-2015 07:14 PM
14-08-2015 07:29 AM
mpilk
12-08-2015 09:40 PM
Zoggon
10-08-2015 10:39 AM
Caddyshack
15
04-08-2015 08:50 AM
Quick Reply: Cosworth YB cam pulley timing position
