cossie piston slap????
Old Mar 8, 2005 | 06:56 PM
markevans's Avatar
markevans
Default cossie piston slap????
Do all 2wd cossies suffer if so why and is it normal and should it be repaired????
Old Mar 8, 2005 | 07:21 PM
SteveB's Avatar
SteveB
2wd Cossies in std out of the factory trim had central gudgeon pins on the pistons so the yslap when cold.... the latter 4wd pistons had an offset gudgeon pin so stopped the slap...
Old Mar 9, 2005 | 05:18 PM
Alvyn's Avatar
Alvyn
Default Re: cossie piston slap????
as said above the only way to repair it WOULD be to use 4x4 pistons
Old Mar 9, 2005 | 05:25 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
Hi Mark, are you from the US??
like the others said you need the 4x4 pistons, which I might have.
Old Mar 9, 2005 | 05:28 PM
markevans's Avatar
markevans
no sorry do not live in the us. Does this mean all 2wd drive pistons slap?
Old Mar 9, 2005 | 06:15 PM
Alvyn's Avatar
Alvyn
yes some MORE than others
Old Mar 9, 2005 | 08:58 PM
cossied's Avatar
cossied
Default slap
even RS 500s
Old Mar 9, 2005 | 09:20 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
mmm strange, i have a 4x4 engine, 200 block and also a piston slap
Old Mar 9, 2005 | 10:22 PM
Alvyn's Avatar
Alvyn
u SURE its not the cam followers your hearing as they slowly fill up of oil(due to age/mileage) maybe lasting up to a few minutes rather than it being piston slap from your 4x4!
Old Mar 10, 2005 | 04:55 PM
Mechanic_Wedgie
No it's not the cam followers, that's another sound, my cousin has got that sound from the cam followers.
Only with a cold engine for 1 or 2 minutes, no problem for me, no oil use.
Old Mar 14, 2005 | 10:15 AM
Daveyraveygravy's Avatar
Daveyraveygravy
Me too Wedgie, I'm glad im not the only one now
I had my tappets changed for new ones (From Fords - Expensive!!!) and i've still got it. Mines an early 4x4 Red top engine without the cat.
Just learned to live with it now, I just let it warm up/cool down properly and change the oil every 3k.
Old Mar 14, 2005 | 02:32 PM
ian rst's Avatar
ian rst
Mine souds like piston slap and i have an esc cos
Old Mar 18, 2005 | 03:27 PM
cossied's Avatar
cossied
Default slap
pistons are alloy, block is steel as they expand at a different rate there has to bee more tollerance, as the piston warms up and expands more than the block the slap should dissappear
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
