Cosworth inlet manifold
Sep 26, 2012 | 03:03 PM
Hi ppl
I have got a small turbo escos inlet and wanna no if I can make this work with l8 ecu as the tps are diffrent
Sep 26, 2012 | 03:42 PM
just fit the 4x4 throttle body bolts straight on
Sep 26, 2012 | 06:05 PM
Isn't that defeting the object as the tb is smaller ?
Sep 26, 2012 | 06:52 PM
is there a difference between then? I though all the inlet trumpets are the same and the plenum cover and TB are different between a 2wd, 4x4 ( saff & escos) and 500?
Sep 26, 2012 | 07:05 PM
all plenums are slightly diffrent but the small turbo escos uses a bigger tb
Sep 26, 2012 | 07:13 PM
Quote:
Originally Posted by
scholes
yes it is smaller than the small turbo throttle body but unless your after more than 650hp then the 4x4 one is fine as thats what it will flow.
Derek Burleigh
Sep 16, 2015 06:27 PM
Russ Hill
Aug 31, 2015 06:44 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
mick pearson
Aug 9, 2015 09:19 AM
