mondeo diesel no pull
Old Sep 17, 2012 | 06:26 PM
eddiebongie's Avatar
eddiebongie
Default mondeo diesel no pull
hi all realy after some helpful advise my daughter has got a mondeo 03 2ltr tdci, problem is it starts ok first turn of key no smoke tick over ok problem is when you pull away it pulls upto 1500rpm hesitates up to 2000rpm then there is no power car will gradualy get up to speed cruise on motorway 100,110 no problem , ive cleaned all the crap out of egr valve and inlet manifold checked all hoses for leaks and nothing what do i check now
Old Sep 17, 2012 | 07:07 PM
RichieST's Avatar
RichieST
Is the EGR valve working properly? They do give a lot of problems on the diesels. Even if it has been cleaned it could still be faulty. I've blanked the EGR off on my tddi mondeo.
Old Sep 19, 2012 | 04:56 PM
eddiebongie
i can only assume it works as not realy sure how to check them i will blank it of on saturday see if that has any effect on it
wowk
Mar 30, 2021 07:49 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
