Fuel pressure
Old Sep 8, 2012 | 11:40 AM
BIL N KEL's Avatar
BIL N KEL
Default Fuel pressure
We are just about to start up my brothers Zetec turbo fiesta rst for the first time. I've got a fuel pressure gauge on the reg but what pressure should it be running roughly. It's a new aftermarket reg with aeroquip fittings. I thought it should be around 14psi but was unsure
Old Sep 8, 2012 | 08:14 PM
opposite lock's Avatar
opposite lock
I would think its around 3 bar at the rail if not more please dont quote me on that though . I think the cossies are 3.5 bar at idle and im going by that.
Old Sep 8, 2012 | 09:58 PM
BIL N KEL's Avatar
BIL N KEL
I set it to 1bar and it wouldn't start. When I for home I had a quick search and found people quoting around 3-3.5bar. Will try that tomorrow and see what happens
Old Sep 9, 2012 | 11:16 AM
opposite lock
I quickly had a look at technical articles on fuel pressure and funnily enough the frst pump is mentioned and its seal (internal o.e pump) with a limit of 5bar pressure . It must be a common known issue with big spec frst's. Do some research on it as you maybe near the limit if high boost.
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
