STALLING PROBLEMS!!!
Old Mar 6, 2005 | 01:21 PM
andre_k's Avatar
andre_k
Default STALLING PROBLEMS!!!
hi i have had this prob with my 1989 efi 3i cabriolet, every time i depress the clutch (eg junctions) the revs drop to a bout 500 rpm before either a) pick up to normal idle speeds or b) stalls.
in order to solve probs i have fitted another ISCV, CO2 pot, inlet gasket, head gasket (see below)
i swapped the head gasket because she was chuffing out white smoke even after driving for an hour or so (when removed head seemed old gasket looked fine), yet it seems both the smoke and stalling probs are there
any ideas???
also, what should turning the screw on the co2 pot do, as turning mine on both the old and new (well off a smashed 2i) co2 pots does nothing...
any help would be good
cheeRS
dre
Old Mar 7, 2005 | 12:33 PM
whale tail's Avatar
whale tail
try replacing yourfuel filter if it is clogged u could be starving your eninr of fuel
Old Mar 7, 2005 | 12:38 PM
whale tail's Avatar
whale tail
also check for vacuum leaks around the inlet manafold, if there is a leak you may be able to hear a sucking sound for a few seconds after the car is switched off
Old Mar 7, 2005 | 01:58 PM
turbo.jon's Avatar
turbo.jon
clean out the flap on the bit saying efi that opens when u put foot on peddle you need to take off air box pipework to get to it dont no what its called use some carb cleaner in a can or any other de choke stuff as its proberlly sticking as i had same prob on my old efi 2i i had
Old Mar 7, 2005 | 04:39 PM
andre_k's Avatar
andre_k
u mean the throttle butterfly? the flap that allows air in? changed inlet gasket so no leak there, but will try the fuel filter next time i get paid, i did change the air filter and that was really manky so i guess the people before me never serviced it! ah well its had some tlc the last few months lol
Old Mar 8, 2005 | 08:48 AM
turbo.jon's Avatar
turbo.jon
yep thats the thing mate it done same thing on mine it kept sticking i sprayed it with cleaner and it worked fine after that
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
