Advice on megasquirt
Old 04-09-2012, 12:31 PM
Windy RST
Windy RST's Avatar
Default Advice on megasquirt
Hi everyone after a bit of advice on a stand alone ecu for my 2.1 zetec turbo.
Basically I'm thinking of running a megasquirt set up but not sure which one to go for?
Has anyone recently done the conversion themselves and could shed some light on the subject?
Are the base maps easy enough to get hold of and install ?
Also do I have to run megasquirt sensors?
Old 04-09-2012, 12:43 PM
basty
basty's Avatar
Hi
If you really want to go the MS route you best go and check www.mtechautomotive.co.uk
KarlosG on the forum here also know a fair bit of MS.
The sensors from ford or vauxhall can be used so check the www.msefi.com lot of answers there.
Or the route i would go speak to Jano @ oddkiddcreations.co.uk for weber management
as its proven to work with lots of OEM+ parts and not that expensive IMO.
cheeRS
Old 04-09-2012, 02:38 PM
Windy RST
Windy RST's Avatar
Thanks mate will check out the links.
Old 05-09-2012, 08:59 PM
saph_Al
saph_Al's Avatar
Hey bud i'm curent in the middle of getting my shit together to MS my cossy . With regard's to base maps theres plenty on maps that will get the car running so you can start to alter your fuel and spark tables to something like but i wouldn't recommend trying to drive the car on it . As for sensors MS is designed with GM sensors in mind which are easy to get hold of however it is possible to use ford sensor's but takes a little fucking about . have a mooch at www.boostmonkey.co.uk . It's run by Rob from here Rob_DOHC . He knows his shit and will be able to steer you in the right direction . Dependent on what managment you currently have he may even be able to sort you out with a PNP unit .
Old 15-09-2012, 10:19 PM
HirenRS
turbovh
HirenRS's Avatar
Default megasquirtin
im going standalone on my 2.0 zetec turbo too lost it last time round to det have been building it back up since i have seen an item on ebay which i got my eyes on aswell what do yo boys reckon? http://www.ebay.co.uk/itm/MegaSquirt...item3f1a0caae9
mk3ste
17-10-2021 10:09 AM
gcfcos
59
06-10-2015 05:04 PM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
Marv888
26-09-2015 03:44 PM
Quick Reply: Advice on megasquirt
