clutch problems
Old Mar 5, 2005 | 05:55 PM
cossey paul's Avatar
cossey paul
Default clutch problems
can any1 help me please b4 i go mad , i have fitted a ap organic clutch plate cos the old 1 was badly slipping and the new 1 is doing exactly the same any1 got any ideas ?
Old Mar 5, 2005 | 06:15 PM
mcgoo's Avatar
mcgoo
have you fitted just a plate or the complete 3 piece kit, plate, cover and release bearing?
Old Mar 6, 2005 | 09:42 AM
cossey paul
the 3 piece kit standad cover and bearing and ap organic plate
Old Mar 6, 2005 | 10:40 AM
nikh667's Avatar
nikh667
Is the cable no good, or clutch rachet on pedal perhaps holding the clutch on slightly? Was the flywheel face ok - not blued, damaged or moreso contaminated with oil etc.. when replaced?
Old Mar 6, 2005 | 11:37 AM
cossey paul
its a brand new cable the flywheel was a little blue but didnt look 2 serious , was no oil on it whatso ever i am just about 2 go change the ratchet see if that helps fingers crossed
Old Mar 6, 2005 | 09:11 PM
mcgoo's Avatar
mcgoo
GGR told me that you couldn't use an ap organic plate with a standard cover
Old Mar 7, 2005 | 07:58 AM
swerv's Avatar
swerv
I got told this by an AP agent as well
the flywheel must be ground as well, it could cause problems.
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Rammer46
Sep 18, 2015 08:31 AM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
