What will Grey injectors max out at?
Old Aug 23, 2012 | 01:58 PM
booner999's Avatar
booner999
Default What will Grey injectors max out at?
Hi All,
What kind of power will Gray injectors max out at?
Running on a T34.63
Also what is the max amount of boost grays and the turbo above could handle and what kind of boost is producing what power?
Say two bar of boost as this is what most with these injectors are running.
Interested to know the next step in power and what it can achieve
Thanks
Mark
Old Aug 23, 2012 | 02:39 PM
J1mbo's Avatar
J1mbo
B1mbo
Grey injectors are flat out at 450bhp.
The t34.63 will do just over 400bhp but not for long.
When talking boost you need to know what it holds at 6500/7000rpm.
You can run the big boost in the mid range, something like 2.2 bar is what we use. And by 6500 drop to 1.8/9bar and will give a gen 400bhp. With a ported head and inlet cam.
The .48 is a better exhaust housing IMO for the road. Alot more punchy and only a 20bhp and a few hundred rpm sacrafise up the top.
Old Aug 23, 2012 | 08:02 PM
booner999's Avatar
booner999
What would it be at around 2 bar? Would that be safer for the turbo? Would you recommend a dump valve for that?
Cheers mate
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
