Tech Help needed....pleeeeze
Old Mar 5, 2005 | 05:14 PM
starturbo's Avatar
starturbo
Default Tech Help needed....pleeeeze
My series 2 has struggled to get to 50 degrees C for a week now and I know its not the gauge coz the heater is luke warm.I put a new thermostat in it today and nothing has changed.Any ideas fellas.Any help would be most appreciated.
Old Mar 5, 2005 | 06:59 PM
davidnormanuk's Avatar
davidnormanuk
Try flushing your coolent system out. The heater matrix on them tends to clog up.
Worked with mine.
Dave
Old Mar 5, 2005 | 07:11 PM
tiny's Avatar
tiny
Cover the rad with cardboard, just to see if the temp goes up, if it does,you
know its just because its fookin freezin out side, hth
Old Mar 5, 2005 | 07:45 PM
Al Bags's Avatar
Al Bags
Said this before in another thread .. Check the outlet elbow to the heater supply pipe is not blocked up by scale. You may need a drill bit and/or wire to do this.
I found two like this, both CVH engines with angled elbows.
Good luck anyways
Old Mar 13, 2005 | 04:20 PM
starturbo's Avatar
starturbo
Worked with mine.
Dave
surely it cant be clogged coz the gauges x2 are showing a low temp and i can touch the pipes with my hand when its been running.I stuck a new thermostat in it and its made no difference?Its bloody freezin at three in the mornn.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
