Cossie Amal Valve
Old Aug 19, 2012 | 09:51 PM
shortie's Avatar
shortie
Default Cossie Amal Valve
on a cossie amal valve the port that goes to the actuater is there supposed to be a little plastic restrictor in the end
Old Aug 19, 2012 | 10:09 PM
Rsmat's Avatar
Rsmat
Yup.......
Old Aug 20, 2012 | 09:55 AM
shortie's Avatar
shortie
Thanks Matt
Old Aug 20, 2012 | 09:59 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
no
the waste gate port is empty (W port)
the c port and the r port have the restrictors fitted as std
Old Aug 20, 2012 | 10:38 AM
shortie's Avatar
shortie
Ok Tony thanks i can't understand why ive lost so much boost it's gone from 30 down to 15
Old Aug 20, 2012 | 12:11 PM
martysmartie's Avatar
martysmartie
You asked the same question in another thread, and when I said what is the "Amal" you doing, you replied and said "clicking".
I then said the valve itself is bad or the TPS calibration...
Martin
Old Aug 20, 2012 | 06:29 PM
shortie's Avatar
shortie
Totally different question i was asking
Old Aug 21, 2012 | 07:55 AM
martysmartie
But you then go on to say you can't understand what is causing the issue, which will be down to the clicking valve.
Martin
Old Aug 21, 2012 | 12:12 PM
cossie891's Avatar
cossie891
Tiny do you have to have both plastic bits in the Amal
Old Aug 21, 2012 | 08:48 PM
tosh's Avatar
tosh
I have got Carb jets in mine??
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
rs_jim
Sep 19, 2015 08:41 PM
