Help and advice needed please
Old Aug 15, 2012 | 11:06 AM
lee s1's Avatar
lee s1
Default Help and advice needed please
hi all i am in need of some help with an issue on a s2 Here goes
The car will start and run fine from cold then once hot it looses power and starts to black smoke from exhaust Having had a quick poke round i have found if you un plug the black box on the right hand side of the meetering head the miss fire goes as does the smoke and drives fine plug it back in again and fault returns let it cool down and its all good again untill it gets hot any ideas as to what is causing this fault
Thanks in advance lee
Old Aug 15, 2012 | 11:25 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
fuellings way out mate, get it to a tuner to be set up. mine had same problem
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
