failed mot :( simple things need help
Old Aug 11, 2012 | 08:17 PM
clyde 1800's Avatar
clyde 1800
Default failed mot :( simple things need help
failed mot on little easy fix things
1)no pins in the trackrod ends my bad
2) and no rear fog light
although theres 1 comes on on the left
should there be 2?
or have i wired it wrong? should the left hand tail light spud be on the right?
basically i want to know does a sierra have 1 0r 2 rear fog lights??
Old Aug 11, 2012 | 09:44 PM
johnnysash's Avatar
johnnysash
Fairly certain they have 2 fog lights Your mot tester sounds a bit picky!
Old Aug 11, 2012 | 10:37 PM
Moonstone Mart's Avatar
Moonstone Mart
Rear foglamp should be on the right if it only has one.
Old Aug 12, 2012 | 12:39 AM
clyde 1800's Avatar
clyde 1800
you see i checked all my lights before i went and i didnt know about the on the right or middle rule for the fog lights
my fog light is on the left and it basically is just the tail light lit up solid
i rewired the car maybe i put the right to the left by accident?
or maybe the sierra has 2?
Old Aug 12, 2012 | 09:13 AM
Moonstone Mart
Yes I think they do have 2.
Old Aug 12, 2012 | 11:49 AM
clyde 1800's Avatar
clyde 1800
thankyou mate
il have a look at it later i dont want to think about having to take the interior out again and fix wiring
Old Aug 12, 2012 | 12:27 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
UK MOT only requires 1 Rear Fog lamp to work but it MUST be on the Offside (Right Hand) Rear
Even if vehicle has provision for 2 rear fog lamps only the O/S/R must work
As for the split pin missing - if you cannot remove any old split pin debris simply remove castle nut and fit a new Nyloc nut
Old Aug 12, 2012 | 02:29 PM
nicksaph's Avatar
nicksaph
or the centre, lilke the 206
cheers nick
Old Aug 12, 2012 | 02:30 PM
RS2000CUSTOM
cheers nick
Old Aug 12, 2012 | 06:04 PM
nicksaph's Avatar
nicksaph
lol....
Old Aug 20, 2012 | 07:37 PM
clyde 1800's Avatar
clyde 1800
thanks folks shes up on wednesday again
Old Aug 20, 2012 | 11:09 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
The fog light bulbs are twin filament bulbs, along with tail lights, ie next to the indicators on both sides. Often a dodgy connection or blown bulb, especially if the other side is working. If you don't have a spare bulb, swap left for right for the MOT. As said, you only have to have one but it must be to the right or centre, not just the left.
Old Aug 21, 2012 | 08:08 AM
clyde 1800's Avatar
clyde 1800
its actually a bad connection to the cluster i have it twisted some shape so all works but in scared of it falling out of place again how would you fix this??
Old Aug 21, 2012 | 08:13 AM
clyde 1800's Avatar
clyde 1800
one of the trackrod ends didnt have a hole for the split pin so i drilled myself one
Old Aug 21, 2012 | 08:16 AM
clyde 1800's Avatar
clyde 1800
pic of her last time home from the failure
one more day until the retest
Old Aug 21, 2012 | 08:24 AM
rsfido_1989's Avatar
rsfido_1989
Amazing trailer
Old Aug 21, 2012 | 03:37 PM
gjh's Avatar
gjh
Thats a well smart trailer unit, tidy saph too. Hope it passes this time for you.
IainRS1700T
Sep 25, 2015 06:44 AM
Botts
Sep 22, 2015 02:04 PM
Karl @ FPT
Sep 21, 2015 11:02 AM
Ronnie Scott
Sep 20, 2015 10:21 PM
richierich1986
Sep 18, 2015 03:29 PM
