1.8 mk2 Mondeo Help
Old Aug 10, 2012 | 02:19 PM
Ianbhoy's Avatar
Ianbhoy
Default 1.8 mk2 Mondeo Help
Desperate for help.
After frying the clutch the car would not start again.
Towed to garage who replaced the clutch and cam sensor but still failed to start. Garage at a loss so after £355 changed hands car towed home again.
ECU sent to ECU Doctor and came back with no fault found (another £45).
Since then all relays been replaced along with crankshaft sensor, all cables & relevant plugs checked with testing of cabels as far as I am able and no faults found. Checked all fuses and fuel pump all ok.
Appears that I am not getting fuel into the engine nor am I getting a spark at plugs.
Have attach car code reader and faults being highlighted
Any one out there with any ideas (apart from scrapping motor) or where next to look? Also quick comments how to do any other checks appreaciated.
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
Sp3no
Sep 27, 2015 07:23 PM
