Mondeo 1.8 mrk 2 2000 year
Hi all
Hope some one can help.
Couple of weekends back while trying to reverse a trailer up a slight incline I managed to burn out the clutch on my W reg 1.8 mondeo. Not only did I burn out the cluch I also managed to knacker the Cam sensor. Now that clutch and cam sensor have been replaced the car will not start and has been sitting in a garage with the mechanics scratching there heads on faults.
It appears that no power is reaching the ECU which in turn will not allow for the car to attempt to start. Fuses and relays have been checked and appear ok as is the fuel pump (however plugs are not damp when removed after attempting to start).
Any one out there able to provide any possible solutions to the problem?
Thanks in advance.
Thanks in advance.
