ecu help!!!!!
Old Jul 19, 2012 | 08:56 AM
nomad29's Avatar
nomad29
Default ecu help!!!!!
Hi all i seem to be having difficulty with wich i do believe to be my ecu i was driving down the road and it just stopped the engine will turn over with no problems so i did the usaul checked the cambelt then proceeded to do other checks no spark so changed the coil pack tested the wiring also still nothing changed the crank sensor wich just leaves the ecu the trouble i have is my ecu code is*...*98AB-12A650-CDG*... But i cannot find a second hand one at all as ideally i will just change this and the lock set so will another ecu that is say 98ab 12a650 cff or similar work my focus is a 1.6 16v? many thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
