A little brake question
Old Jul 17, 2012 | 08:30 PM
James Edgar's Avatar
James Edgar
Question A little brake question
At the moment I am building my 2.0 dohc cossie rep
I am using 4x4 cosworth running gear at the rear I'm just wondering wil 2wd calipers fit 4x4 hub and will 4x4 calipers fit my 2wd front hubs
So Basicly will all calipers fit all hubs?
Thanks
Old Jul 17, 2012 | 08:48 PM
martysmartie's Avatar
martysmartie
No, 4x4 may well do as they were just simple sliding affairs like found on other models, the 2WD however has unique 4 pots which I believe will only fit the Cosworth 2WD hubs, also the offset is different, hence why you can't fit 2WD front brakes to 4x4.
Dependent on the current braking system currently fitted it may not be man enough to operate the 4 pots either.
Martin
Old Jul 17, 2012 | 08:53 PM
James Edgar
So I'm best off buying cosworth 2wd hubs for the front and run 4x4 brakes on the rear and 2wd on the front?
Old Jul 17, 2012 | 09:00 PM
martysmartie
The rear brakes are the same as lesser models, but obviously they have bigger discs (273MM) and 4x4 are vented and so have different calipers but you can interchange the two.
Yes so far as I know re the fronts and Cosworth 2WD hubs that would be the easiest way in terms of fitment but then you need to consider the physics, as I say.
Martin
Prickly_buzz
Dec 7, 2017 09:52 PM
155lee
Oct 27, 2015 04:55 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
