mk2 mondie st200 estate, traction control switch pinout needed
seems i cant keep anything standard for very long so having bought an st200 estate i thought i'd have a play till i finish the st200 mk6 escort, so does anyone have a pin out diagram for the traction control switch and does anyone know if the switch is a push on push off type or is there some sort of voodoo going on inside requiring the sacrifice of small animals to make it stay on? any help much appreciated.
I will try and dig out the diagram for you. It is just a push off/ push on switch as it is on until you turn it off and then the light illuminates. If you turn the car off with it switched off it will be on when you restart the car.
155lee
14-09-2015 07:37 PM
blakey100
04-08-2015 08:17 PM
Escortdriver1
31-07-2015 02:36 PM
