none starter yb
Old Jul 13, 2012 | 07:54 PM
footlongphil's Avatar
footlongphil
Default none starter yb
will someone help.....i have put a yb into a mk1 escort and it will not START i have a good spark,fuel pressure (cossie pump not a cheap far east one) cranks over well but the plugs are bone dry !!!!!
Old Jul 13, 2012 | 07:57 PM
cozzy jeff's Avatar
cozzy jeff
have you checked for power to the injectors?
Old Jul 13, 2012 | 08:00 PM
footlongphil
i could if i knew how.....
Old Jul 13, 2012 | 08:04 PM
cozzy jeff's Avatar
cozzy jeff
remove the plug from the injectors and check for 12v with ignition on,the earth is pulsed to fire the injector.
Old Jul 13, 2012 | 08:12 PM
footlongphil
cheers,i will do in the morning..if no live is it down to the ecu ???
Old Jul 13, 2012 | 08:35 PM
cozzy jeff's Avatar
cozzy jeff
im unsure,the ecu switches the earth not the live feed.
Old Jul 13, 2012 | 08:41 PM
footlongphil
ok cheers,i have done the conversion before with no problems,it started first flick,but this one has been a pain from start ,cheers
Old Jul 13, 2012 | 09:24 PM
footlongphil
just checked the injectors and have no voltage (0.20)..what now the world ???
Old Jul 13, 2012 | 10:05 PM
cozzy jeff's Avatar
cozzy jeff
You need to check you've got power to the ecu,also check that all your sensors are plugged in and gapped corectly
Old Jul 16, 2012 | 08:15 PM
martysmartie's Avatar
martysmartie
The OE setup powers the injectors via the ECU relay, so long as they have a switched 12V + supply, as said the ECU switches the ground.
Martin
Old Jul 16, 2012 | 09:24 PM
footlongphil
thanks for your help..poxy relay,all good and running well,cheers
Old Jul 17, 2012 | 06:29 PM
cozzy jeff's Avatar
cozzy jeff
good stuff easily sorted
Old Jul 17, 2012 | 08:36 PM
martysmartie
Glad it's sorted.
Martin
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
