Ford Escort Van 1.8d
Old Jul 12, 2012 | 05:21 PM
Adsmith's Avatar
Adsmith
Default Ford Escort Van 1.8d
Hi all just wondered if you could help me, I have just replaced the timing belt on my van but after putting it back together I have a problem
It just wont idle & there is alot of smoke. I think I might know what the problem i s but i am not sure. When I was lining everything up for TDC the pump was off by about half an inch so I undid the 3 bolts on the pulley & moved it slightly then tightened it back up Any help of where it should be?
Thanks
Old Jul 12, 2012 | 08:42 PM
Adsmith's Avatar
Adsmith
bump..
Old Jul 13, 2012 | 07:37 AM
Adsmith's Avatar
Adsmith
Any one know?
Old Jul 14, 2012 | 05:16 PM
cabriolet's Avatar
cabriolet
think u are right u need to find a mate with a snap on timing light and the diesel converter he will be able to strobe the pump in
Old Sep 15, 2013 | 09:31 AM
ashbash2013's Avatar
ashbash2013
hey adsmith did you ever sort the problem out on your van if so what did you do ihave the same problem wont idle and lots of smoke
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
