noise from gearbox or clutch helpp
02-03-2005, 05:31 PM
i get a screaching noise from when i lift my foot off the clutch but then goes when you drive its only when you pull off. it will do it in all gears is it the clutch
02-03-2005, 09:30 PM
02-03-2005, 10:27 PM
what clutch do you have fitted ? I know paddle clutches do this !
02-03-2005, 11:05 PM
its standerd one never did it befor think its the clutch
04-03-2005, 02:02 PM
Sounds like your diff is fooked
04-03-2005, 08:19 PM
it could be the thrust bearing in the clutch
06-03-2005, 11:14 PM
it turn out to be spigot bearing
arkeye
Ford Focus ST
20-02-2016 01:22 PM
mjonathan24
29-10-2015 10:39 PM
gingeRS
17
02-10-2015 09:42 AM
A.t.p
29-09-2015 05:04 PM
