Focus 1.6 engine conversion questions PLEASE HELP!!
Old Jun 14, 2012 | 08:55 PM
mattie.papworth's Avatar
mattie.papworth
Default Focus 1.6 engine conversion questions PLEASE HELP!!
Hi all,
first of all im new to the site so hi to you all..... right i have a 03 plate ford focus ebony 1.6 im wanting to do an engine conversion on it to a 2.0l (im not just buying an engine, im going to do it properly and buy a donor car..) now i know the focus 2.0 engine will go in ok oveously because its the same chassis but 2.0l focus cheap are few and far between.. i have seen 3 ford mondeo 2.0l zetec for sale round my town low milage engines just rotten chassis for between 150 and 200 and its the 2.0l back top (plastic rocker cover) engine, it looks like the same engine out the focus, but im not shore would anybody be able to shed some light on the situation lol if i bought the full car would i be able to do the same conversion as if i bought a 2.0l focus? thanks guys
Old Jun 14, 2012 | 09:04 PM
martysmartie's Avatar
martysmartie
Far more involved than you think, firstly the inlet and exhaust are on opposing sides.
You then also have suspension differences as the Zetec-E (2L) is heavier, do a search on here and you will see where someone has listed all the different things.
To answer your question, yes, Mondeo MK1/MK2 1.8/2L is the same engine as the Focus etc.
The 1600 Focus (Zetec-SE) engine was launched with the Focus and shares nothing in common with the other engines bar the name.
Martin
Old Jun 14, 2012 | 09:11 PM
mattie.papworth
hi mate yeah i know the engine is the other way round as im a mechanic and work on them lol just dint know if the were edsactly the same as for the weight im track daying the car so i have some coilovers on the way so the weight shouldnt be a problem as the kw coilovers were the same part number for the 1.8/2.0 and st170 as whats listed for mine, thank you for you time in replying, other thing was, will the gearbox have the same mounting point do you know? and the gear selector cables would they fit into the focus, if you dont know i will have to have a nosie round the next one that comes into work haha
Mattie
Old Jun 14, 2012 | 09:17 PM
mattie.papworth
sorry i dint mean that to sound nasty when i said "yeah i know the engine is the other way round as im a mechanic and work on them" i dint realise it sounded like that sorry fella i do appologise
Old Jun 14, 2012 | 09:19 PM
martysmartie
Coilovers may well do but they are adjustable, but the normal spring ratings are different due to the extra weight, and in the ST's case the springs will be different as it has a lower ride height!
Not sure if the gearbox mounting points are different, probably though as the 2L has a different gearbox (MTX 75)
Yes the Focus also has selector cables so they should be interchangeable in theory.
As I say if you do a search on here there is a thread where everything is listed that needs doing.
Martin
Old Jun 14, 2012 | 09:25 PM
mattie.papworth
thanks for your time martin you have been a great help i will start a build thread when i get one bought thanks fella
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
