rs turbo running rough
Old Jun 6, 2012 | 09:30 PM
rsbridgey's Avatar
rsbridgey
Default rs turbo running rough
dont know if its the spark plugs
or the firing order any one know the proper
firing order with a guide how to do it
thanks
Old Jun 6, 2012 | 09:59 PM
martysmartie's Avatar
martysmartie
Firing order is 1-3-4-2, look at the distributor and the direction it rotates, with the engine at TDC the rotor should be at what should be @ cylinder 1, so this HT lead connects here, and then in the sequence I say above.
But unless someone has been playing with the leads they will be correct.
Martin
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
