2.0 Zetec Conversion HELP
Old Jun 3, 2012 | 08:23 PM
paulsheerin's Avatar
paulsheerin
Default 2.0 Zetec Conversion HELP
Ok Im building up my Mk3 Fiesta with a 2.0 Zetec, It should only be a week or two from being ready to go but I'm getting a bit worried about if its going to work or not. Ive tried searching but I can't seem to find a conclusive answer.
The car has an RS1800 loom from front to back, and I have a DESK ecu from a Mondeo. Will this setup work or will i have issues with the ECU being internal EDIS and the loom having a connection for an external EDIS module?
Old Jun 4, 2012 | 09:10 PM
paulsheerin
BUMP
Old Jun 4, 2012 | 09:13 PM
mattxr3i's Avatar
mattxr3i
I think you need the loom to match the ECU - do a search as it's been covered.
As an aside, you may want to consider going OMEX or equivalent as you will need aftermarket management if you modify it a lot
Old Jun 5, 2012 | 05:45 PM
frsjon's Avatar
frsjon
a mate of mine had the same issue and im sure you need to change the loom..search for martinxr on fiestaturbo.com
Old Jun 5, 2012 | 05:55 PM
paulsheerin
Trying to find some of the posts on fiestaturbo now but I have to wait til an Admin makes me a member.
Have been doing a bit more digging myself and it looks like I can either modify the loom or run a 130 Spec ECU from an RS1800. Performance differences are meant to be minimal.
Oh and had a look at OMEX but its just not affordable at the time being. maybe next year. Thanks though
Old Jun 6, 2012 | 08:19 AM
zippyobrien's Avatar
zippyobrien
If you want to run a desk ecu then you need a internal edis loom from a fiesta si.
Although rs1800 management will run it fine.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
