cant get my rs turbo started its turning over but not starting its sparking
it tries to start then wont
An eye for detail...
If you've put battery on make sure the small brown wire coming under the heater blower plastic, with the small ring in the end is connected to negative. I missed this after doing bodywork on mine and it's the earth for fuel pump relay.
It should be cable tied to the other negative lead. Mine wasn't.
The Underdog
29
07-09-2015 09:49 PM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
