hand brake stuck on
Old May 30, 2012 | 09:40 AM
rammer's Avatar
rammer
Default hand brake stuck on
Hi All
Just returned after 5 days away and my MK 1 mondeo started no problem but when trying to move it the rear left wheel is stuck on, no problems before, I have took the wheel off but cannot get the hub off, the shoes seem to have locked up, hanbrake cable seems to be free, any advise what the problem could be and how do I remove the hub please, I can only assume the adjusters are up tight,
thanks in advance
Rammer
Old May 30, 2012 | 10:26 AM
james kiely's Avatar
james kiely
if its a drum brake ,hit it with a hammer till it frees up mate.
i had to do this to my sisters car last week after a week parked up in the airport carpark .
Old May 30, 2012 | 10:51 AM
rammer's Avatar
rammer
Thanks James
I am just a bit concerned the drum will shatter . I will try with a rubber one first and then with a bit of wood to soften the blow, I will let you know how it goes thanks again
Rammer
Old May 30, 2012 | 12:19 PM
rammer's Avatar
rammer
Hi James
Gave it a good feew whacks and it seems to have sorted it thank you very much for the help,
Regards
Rammer
Old May 30, 2012 | 12:39 PM
martysmartie's Avatar
martysmartie
The moral of the story is don't leave the handbrake applied when the car is not going to be in use for a period of time.
Once you have freed it initially the heat will unbind it!
Martin
Old May 30, 2012 | 12:46 PM
james kiely
Originally Posted by rammer
Hi James
Regards
Rammer
no probs mate
Old May 30, 2012 | 04:22 PM
rammer's Avatar
rammer
Thank you Martin and James
Lesson learnt thanks again
Rammer
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
