idling on a 3dr cosworth
Old May 28, 2012 | 11:19 AM
shortie's Avatar
shortie
Default idling on a 3dr cosworth
From cold the idle is up & down now ive changed iscv & the map sensor & it's still does it but it stops doing it when it's warmed up
Old May 30, 2012 | 06:51 PM
Alvyn's Avatar
Alvyn
could a case the mixture is wrong or base idle is set too low and im sure the list no doubt could go on!
Old May 30, 2012 | 07:13 PM
escoskmv's Avatar
escoskmv
got the same problem on mine mate, i think its the blue water temp sensor. im goin to order a new one so will let you no wot happens bud
Old May 30, 2012 | 07:46 PM
martysmartie's Avatar
martysmartie
I have always had this problem, it could be a few things.
I suspect it's your TPS at fault, in your case you can unplug it, as a test, and see if this makes any difference, if so then you need to look at calibrating the TPS etc.
When you say you changed the ISCV, I suspect this will be a pattern one off the bay etc?
If so these arn't that good, I have one myself and whilst it got rid of my hunting problem it run very fast with it, so much so I reverted again.
The reason being is the incorrect springs being used, you can get them to work but they need a lot of playing around with, I have to do this with mine.
Martin
3dr cossie
21
Nov 20, 2015 05:00 PM
CLIVE
Oct 2, 2015 12:58 PM
muffster
13
Sep 3, 2015 09:40 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
