Zetec missfire.
Old May 27, 2012 | 05:30 PM
wakesupremo's Avatar
wakesupremo
Default Zetec missfire.
Been to the classic ford show at santa pod today but couldn't run the 100E because the zetec started missfiring yesterday after the first run at shakey. I bought new plugs, leads and coilpack and still no cure. I've established that it's the number 1 cylinder as the plug comes out soaking wet with fuel. I've compression tested it and all cylinders are bang on equal at 150psi. There is an awful lot of fuel coming out of the cylinder when the plugs removed and engine running. Does anyone know if the injectors can get stuck open?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
