Sierra 2.0i Dohc rattling lifters
I've tried to solve this problem for some time, but it hasn't gone away.
The rattling sound doesn't end at all, it's pretty much the same on cold and warm engine. It doesn't go away even when revving.
I've already changed the lifters for febi/bilstein. Oil pump pressure relief valve plug is checked, it was loose. Oil intake pipe is cleaned.
Oil pressure was about 1 bar at idle, before i cleaned oil pipe.
Haven't checked afterwards.
According to the manual, it should be 1.6 bar.
Im using ford's own 5w30 oil, which is right for this engine to be used in finland.
Engine has been cleaned with diesel & oil mix for several times, no change at all. Oil is clean.
Im running out of options.
chowfornow
14
05-01-2019 09:01 PM
SMILER258
28-09-2015 09:04 AM
