no fuel or spark
Old May 26, 2012 | 03:59 PM
frsjon's Avatar
frsjon
Default no fuel or spark
today i finally get to turn the key on the car ,oil pressures good,fuel pumps primed and fuel at the rail and the engine turns over lovely.but i cant get any fuel or a spark in the cylinders..this is a zetec turbo using emarald k3 manegement .
ive replaced the crank sensor but no change,checked the base map but found no issue. the engine loom is all new and fitted correctly..everything seems to working sweetly bar the fuel/spark .any adivice would be greatly appreciated
just to add ive emailed emerald for there avice but thought id try here as well
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
deathrider666
Sep 28, 2015 06:12 PM
