Coolant temp
Old May 16, 2012 | 09:05 PM
Phil123's Avatar
Phil123
Default Coolant temp
Hi im trying to change the coolant temp sensor on my ford focus mk1
but the problem is I cannot find it! It's a pain in the arse. Could someone help me?
If you have pictures of its placement I would be greatful
Old May 16, 2012 | 09:08 PM
martysmartie's Avatar
martysmartie
It's you look between cylinders 2 and 3 you will see it, you will need to remove the connector and the sensor is underneath.
Martin
Old May 16, 2012 | 09:10 PM
Phil123's Avatar
Phil123
Thank's for getting back to me martin. would you be able to get a picture?
Old May 16, 2012 | 09:23 PM
martysmartie
Look in between plugs 2 and 3 and you will see an electrical connector, can't miss it.
Martin
Old May 18, 2012 | 11:12 AM
Phil123's Avatar
Phil123
Thank's Martin I have found it now.
Mark RS
Oct 12, 2015 06:01 AM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
