Problem with distributor / ignition - SOLVED
Old May 15, 2012 | 10:41 AM
Cyril Sneer's Avatar
Cyril Sneer
Default Problem with distributor / ignition - SOLVED
Hey guys,
actually I have a problem installing the distributor on my cosworth engine.
When I first installed it like it is told in the Cosworth manual, I wasn't able to start the engine.
I tried to fire it up and when the engine stops, it turned for a second in the wrong direction.
This is usually a sign that there is a problem with the ignition.
So I tried to turn the distributor clockwise and it went better and better.
But in my opinion, there is something wrong.
I took some pics of my installation:
Crank wheel/ 1. cylinder is TDC
Cam wheels are pointing together
firing order is clockwise 1-3-4-2
As you can see, the rotor doesn't align with the marking on the housing...
BUT... the idle speed is good and also the acceleration...
I am running a P8 Ecu with a program which i don't know and yellow Bosch injectors.
I guess the engine has about 280 hp...
What is your opinion? Please help...
Thanx allot...
Sneer
Old May 15, 2012 | 03:31 PM
derekd's Avatar
derekd
take out the dizzy og relign it mate its out there in the pic !!
Old May 16, 2012 | 05:12 PM
Cyril Sneer
Problem is solved...
the plug of the phase sensor (see last pic) was inserted wrong...
I turned it and now everything is ok...
maybe it can help others with the same problem...
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
marky_g
Sep 12, 2015 04:26 PM
dms04
Sep 11, 2015 01:57 PM
