PLEASE HELP weird cut-out
Old May 12, 2012 | 04:03 PM
ZeTeC101's Avatar
ZeTeC101
Default PLEASE HELP weird cut-out
I have a escort mk6 1.6 zetec e and have run into a big problem, i was riding one day and all of a sudden it would jerk every now and then almost as it was fuel starvation,so i put new fuel pump in and the problem was still there but getting worse. Then it would start cutting out, and the rev counter jumps irradiculy, if you turn the ignition off and turn it back on without starting the engine its fine the rev counter.I thought it might be the coilpack so replaced that and problem still persists,i thought maybe it was computer box so i got another one and problem still the same, now what i cant understand is the longer i leave the car off the more i can drive before it starts to missfire and jerk and cut_out then the rev counter jumps all over again,almost like problem happens when hot. Please help me. thank you
I dont know if this is right but i unplugged icv and engine cuts out and they say if that happens that means its not broken?
Old May 12, 2012 | 07:22 PM
steve4i's Avatar
steve4i
what's the fuel filter condition? try changing the fuel filter see if that helps
Old May 12, 2012 | 08:16 PM
ZeTeC101's Avatar
ZeTeC101
That was the first thing i replaced,damn tricky one.
Old May 12, 2012 | 09:34 PM
RichieST's Avatar
RichieST
If the rev counter is all over the place I'd be checking the crank sensor. I've seen it before when they work fine but if left to get very hot (sat idling for a while etc) then they fail.
Old May 14, 2012 | 05:26 AM
ZeTeC101's Avatar
ZeTeC101
I really do think that can be the problem, does the rev counter get the signal from crank sensor?
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
muz
Aug 1, 2015 06:48 AM
essexrsturbo
Sep 9, 2004 12:19 AM
