4x4 saff engine removal
Old May 1, 2012 | 11:39 AM
Phil2002's Avatar
Phil2002
Default 4x4 saff engine removal
Is it possible to take out a 4x4 cossie engine and leave the sump in place to basically undo all sump bolts first the lift out engine?
Old May 1, 2012 | 12:04 PM
rog's Avatar
rog
Yes, but you will likely have to cut the pickup pipe as it wont clear the sump when you're lifting it out, and leave the box in.
Old May 1, 2012 | 12:24 PM
Phil2002's Avatar
Phil2002
ah ok i'll bear that in mind. If i cut the pick up pipe can i replace it with a 2wd one as the engine will be having a 2wd sump put on it or will i have to use a 2wd pump as well.
Thanks for the reply.
Phil
JoeyBoyden
Jan 4, 2024 02:36 PM
mrmann
Aug 20, 2015 11:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
