Ford Focus 59 1.6 TDCi heater not working
Hi All,
hot air has stopped working, blows cold air out on all four settings and temp gauge looks ok on dash. you can detect a very slight difference when moving the cold air / hot air dial like its trying to do something but no hot air at all,
any help would be much appreciated
cheers
cheers
the cable is connected to the hot/cold air selector switch and slides into a sort of plastic tube (IIRC), because i kinked it it was pushing it self upwards instead of into the tube so in effect not moving whatever it is connected to at the other end. i ended up just using a tie wrap to keep it straight no problems since
hope that helps,
vdun01
Ford Fiesta
05-10-2017 08:14 AM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
