ABS removal
Old Mar 26, 2012 | 03:19 PM
turboroots's Avatar
turboroots
Default ABS removal
hello
i have a fiesta mk5 zetec s and i would like to take off the abs setup
how easy is it to do
ps its a track toy not road going
Old Mar 26, 2012 | 03:23 PM
lanfire's Avatar
lanfire
rip out all the old brake lines and abs unit, run a single line with a bias adjuster through the car to a t peice at the back, run out of the t at the back to each side and finish with braided lines, up front do the same single line from the MC to a t, then lines to each front finished with braied, the MC has a dual output so one for the front one for the back.
i run the same setup with 4pots up front and rear disc conversion on a mk5 zs.
if your running 4pots upgrade your MC as the std zs one is crap ! im running a none abs mondeo 2003 if i remmember.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
