Fuel Line leak xr3i
How ye lads
Fuel Line leak xr3i
Hi everybody. I've got a 90 mk 4 efi xr3i and its been making a loud hissing noise from under the car for a while now. Sounds like a puncture but i've discovered that its the fuel line. It's where the plastic pipe from the fuel tank clips on to the metal line that runs to the engine. It's a push on fitting. I only went to check under the car properly today because the fuel pump has started getting louder which i assume to be the fact that its working harder to keep fuel pressure. It has started to leak slowly at this fitting and i'm wondering is there anything i can put on it to re-seal it properly. It's been off a few times because of previous fuel pump issues and i assume it's just not as airtight as it was because of this. Any suggestions? Thanks a lot.
JK12
33
26-04-2021 12:09 PM
mike elsome
14-09-2015 04:08 PM
