zetec idle issue
Old Feb 2, 2012 | 12:23 PM
bonkeye's Avatar
bonkeye
Default zetec idle issue
been given a 98 1.6 zetec escort with 67000 on the clock ..... the car starts perfect & idles a very slightly lumpy after you give it a rev the revs to point of stalling some times the revs pick back up but most of the time it dont
took the plugs out that are only 2-3K old & there black sooty but dry...... while running i unplug the air flow meter & there is very slight rev change also unpluged the air sensor half way up the inlet pipe with no change & unplugged the lamda sensor with no change to the revs, there seems to be fluid dripping from the exhaust the car wasnt used for about 5 months then used for 3 months then parked on my drive for 2 weeks might be condensation?
any ideas as this will be for er in doors so im getting an ear full to get it fixed
Old Feb 2, 2012 | 12:41 PM
gouch1's Avatar
gouch1
idle control valve
Old Feb 2, 2012 | 04:18 PM
bonkeye's Avatar
bonkeye
fixed...... thanks fella you was spot on, a pain to get off though in the end i got fed up & went under the car to get it off a little more room! just hope it passes MOT in the morning!
TPM961
Jan 15, 2018 10:50 AM
talon1
Sep 15, 2015 10:27 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
