st boost pressure
Old Jan 29, 2012 | 01:08 PM
westo72's Avatar
westo72
Default st boost pressure
hi
got a problem with the boost on my 2007 st
its only reading 1/4 boost on the gauge anyone any ideas
the car seems to be running fine just down on top end power?
Old Jan 29, 2012 | 01:36 PM
R5FORD's Avatar
R5FORD
has the engine management light come on?
have ou checked all hoses etc..
check your down pipe is still there
any mods?
Old Jan 29, 2012 | 02:20 PM
martysmartie's Avatar
martysmartie
Most likely a faulty "boost control" solenoid.
Martin
Old Jan 29, 2012 | 02:21 PM
westo72's Avatar
westo72
everything looks ok car runs fine just no boost
Old Jan 29, 2012 | 04:40 PM
chrisa3's Avatar
chrisa3
Originally Posted by westo72
hi
Depends if its doing in all gears and engine loads. First gear will likely only read 1/4 boost. The problem with the ST is its boost maps are load dependand if that makes sense. Put it in third or 4th at 30mph and floor the throttle, the boost will likely rise to 3/4 then settle at 1/2.
You could try resetting the CAM fuse (fuse 26). If this doesnt help, could be faulty boost solenoid.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
