converting mfi to efi
Old Jan 23, 2012 | 01:10 AM
rs_hole's Avatar
rs_hole
Default converting mfi to efi
hi i want to convert my escort from mfi to efi, going to use frst parts and ofab ecu.
couple of questions i have are,
do i have to modify fuel tank and if so is it hard?
is the loom just a straight swap?
thanks for help
Old Jan 23, 2012 | 08:21 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Just change the engine harness/loom. I dont remember moding the tank on mine? Changed the fuel pump to one off of a cossie if i remeber correctly and may be the fuel pump relay. Your also need to either change the head to and EFI head or modify the head.
Old Jan 23, 2012 | 08:45 AM
studabear's Avatar
studabear
https://passionford.com/forum/ford-e...2-01-12-a.html
have a read through that
Old Jan 23, 2012 | 03:24 PM
rs_hole's Avatar
rs_hole
thanks guys, my mate just said to me about running the car on cossie management, what do you guys think? is it worth doing, and do you know what i would need?
probably get the wiring done by torque of the devil as they are close to me.
sorry to keep asking questions but want to know what will be best
cheers
Old Jan 23, 2012 | 03:27 PM
DixieTheKid
Pick-up P100 Power!
cheers
You better have deep pockets if your thinking of cossie management!
Old Jan 23, 2012 | 05:26 PM
studabear's Avatar
studabear
cheers
Afaik torque of the devil has ceased trading,
Cossie management would need a cossie engine loom, crank trigger setup, phase trigger set up, inlet modded for cossie throttle body, ecu and suitable map possibly a pectal board, cossie map sensor, injectors, efi inlet. cts and act sensors, and bosses to make them fit inlet, cossie ignition amplifier.
Possibly a few bits I've missed. I've removed cossie management from my car, and will be installing megasquirt
Old Jan 23, 2012 | 06:30 PM
DixieTheKid
Pick-up P100 Power!
Ive forgot about megasquirt, and i think they have just released a new version making it even more DIY'able to make your own maps. Forget all of the about that will be the cheapest option by far! And i know someone with a map to get you started.
steve.rst
Mar 15, 2016 08:01 AM
mondeomark
Sep 28, 2015 06:28 AM
dms04
Sep 11, 2015 01:57 PM
Neil Clark
Sep 8, 2015 07:06 PM
stevierob
Sep 7, 2015 07:09 PM
