gray4850 mondeo tdci flashing glow plug light
Old 21-01-2012, 04:01 PM
gray4850
gray4850's Avatar
Default gray4850 mondeo tdci flashing glow plug light
i have a 2006 mondeo tdci ST. sometimes i start the engine from cold and it starts with no problems but if i turn it off within a couple of minutes if i try to re-start the glow plug light flashes and i have no power. if i leave it for about 30mins it will start again ok. the car is running fine and the light does'nt come on when i'm going. any answers please
Old 21-01-2012, 06:19 PM
bobster1982
bobster1982's Avatar
Glow plug light flashing is putting you in limp mode hence no power. Fault code reader is going to be your best bet to get any DTC codes and the freeze frame data.
Old 21-01-2012, 06:22 PM
gray4850
gray4850's Avatar
i have tried the in-car test by pressing the buttons but its saying 'no faults'
Old 21-01-2012, 07:09 PM
bobster1982
You need a fault code reader mate. the coded you get via the dash display are basic at best and dont list a lot of the powertrain DTC codes.
Old 21-01-2012, 07:12 PM
DanW@FastFord
Spelling Club King!
DanW@FastFord's Avatar
As Bobster says, you'll get nowhere without the fault codes being read.
Starting issues are often linked to the cam sensor, but it's pointless changing it until you've made sure that's what's at fault. Any competent garage will have a code reader and it will take them less than 5 mins to read the codes.
Old 22-01-2012, 10:04 AM
gray4850
gray4850's Avatar
is the cam sensor the same as the crankshaft sensor or two different sensors
Old 22-01-2012, 11:46 AM
bobster1982
Rob Wells
Ford Mondeo Including ST
18-04-2023 12:19 AM
yatta
21-05-2016 10:31 PM
hopper350
04-09-2015 12:53 AM
andrewmctiernan
Wheels and Tyres
03-09-2015 08:22 PM
turbowag
03-09-2015 08:07 AM
Quick Reply: gray4850 mondeo tdci flashing glow plug light
