focus st170 issues
Old Jan 20, 2012 | 12:40 PM
jwright's Avatar
jwright
Default focus st170 issues
i am having couple of problems with my 2003 focus st170 firstly the engine management light keeps coming on ive had the code read and it says "inlet runner control stuck open" but its not affecting the way it drives at all occasionally the light goes out and stays out for roughly 24hrs then its bak on. secondly im loosing brake fluid but i dont know where from as it doesnt seem to be dripping to the ground any help with either of these problems would be majorly appreciated.
Old Jan 20, 2012 | 02:12 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
Last time I did one of them that was loosing fluid it was the clutch master cylinder seals leaking! I take it urs is the same and that ur brake revisiour is for ur clutch aswell? Is your carpet wet inside??
Old Jan 20, 2012 | 03:00 PM
jwright's Avatar
jwright
yeah it does do both the clutch and the brakes the carpets not wet inside im having to refill the resevoir every month
Old Jan 20, 2012 | 06:45 PM
cossie moon
Durham RSOC member
Well you defo have a leak if its not brakes then it must be clutch maybe slave cylinder?? Ull have to check car throughly underneath when its dry and look till you find!
Old Jan 20, 2012 | 06:57 PM
jwright's Avatar
jwright
yeah ill have to get the jacks out thanx mate
Old Jan 20, 2012 | 07:13 PM
cossie moon
Durham RSOC member
No probs mate!
Old Feb 12, 2013 | 05:39 PM
St170_88's Avatar
St170_88
Default Don't know how to create thread
Ok, I have a st170, my clutch was slipping really bad recently so I changed it yesterday, but the new clutch is still slipping. Any ideas what it could be? I changed the DMF aswell, I am really stumped
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
gavt123
Sep 5, 2015 10:03 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Sep 3, 2015 10:49 AM
