Guide for modifying a 4x4 downpipe when running a 2wd manifold?
Old Jan 19, 2012 | 09:03 PM
rog's Avatar
rog
Default Guide for modifying a 4x4 downpipe when running a 2wd manifold?
Going to be running a T4 with 2WD manifold on my saph, I know the downpipe won't fit properly and will need to be modded, can anyone tell me what needs to be done???
I'm aware I need to chop a section out/shorten it, but how much?
Old Jan 20, 2012 | 07:41 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
I always thought you had to lengthen the exhaust to make sure it clears the front prop????
Old Jan 22, 2012 | 10:05 AM
ossie cossie's Avatar
ossie cossie
I may need this info as well. Will be keeping an eye on this thread.
Old Jan 23, 2012 | 11:06 AM
rog's Avatar
rog
So will I, hoping someone replies....
Won't need to mess with the exhaust at the prop area, I'll be modifying a 4x4 downpipe, so the area where it meets the prop should be the same, as far as I remember if you twist the exhaust from the engine bay you orientate the prop clearance from there. Trouble with running a 2wd manifold is that the turbo sits further back than it would do with a 4x4.
Old Jan 23, 2012 | 03:48 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Here you go
Originally Posted by Martin-Hadland
I have had this problem with a T4 fitted to a 4x4 using a 2wd manifold and Mongoose exhaust, the cure was to remove about 20mm from the downpipe as it comes out of the turbo and then put that 20mm band back into the downpipe as it goes downwards.
Originally Posted by trevCOSS
All sorted thanks for the advice Martin
Chopped it up
All welded back together
Fitted and pleanty of clearance
Old Jan 24, 2012 | 03:35 AM
rog's Avatar
rog
Dude that's JUST what I need!!!!
Many thanks, that's just perfect!
jason_nike
Aug 18, 2019 10:53 AM
May 31, 2016 09:28 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
